How to fix Mobee Magic Mouse disconnection issues
Выберете то, что вам нужно
Видеоинструкции
Финишная черта
30 участников успешно повторили данное руководство.
Peter Barnett
Участник с: 09/04/16
732 Репутация
1 руководство автора
Команда
Dragon Upstream Consulting Limited Участник Dragon Upstream Consulting Limited
Business
1 член
Автор 4 руководств
4 Комментариев
I disassembled the Mobee battery pack by removing the 2 tiny screws holding the battery-cover together. One of the batteries had both poles covered with small pieces of greyish tape. Looked like someone forgot to remove them at assembly. I removed the tape. Works well now.
Leuk
BEANTWOORDEN
YatLok Mok - Ответить
I thought I had to buy a new mouse until I found this. Foil proved it. Now for the permanent fix with the solder! Thank you.
Steve Gilbert - Ответить
The batteries inside the mobee are AAA, not AA. I replaced them some time ago :)
Arjen Gerstel - Ответить
I use regular rechargeable batteries, not Mobee ones, but also had a lot of random disconnects. Had read all I could find on the subject but no luck. Finally understood that the problem is on the pointy end of the batteries! So far so good, no more disconnects! Thank you!
cazumanc - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 55
За последние 30 дней: 184
За всё время: 36,328
