How to fix a blown heater element in a Toaster
Выберете то, что вам нужно
Видео обзор
    • Insert wisdom here.
    • how to fix a toaster
Заключение
Not too difficult, you need patience though.
4 участников успешно повторили данное руководство.
jon
Участник с: 05/15/16
2 949 Репутация
Автор 22 руководств
2 Комментариев
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
mitchell.drury - Ответить
Mine is still working even after all this time (over 2 years ago). If your heater element is still connected (low resistance) then the fault is somewhere else. Trace the resistance of connections back through the switch to the plug to find the fault.
jon - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 41
За последние 30 дней: 169
За всё время: 25,045
