Введение
The blown element stops the toaster working, but the wires can be rejoined over the blown section, with very little detrimental effect. See this fix in this video guide
Выберете то, что вам нужно
Видеообзор
Not too difficult, you need patience though.
5 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
