How to fix a break in a Belkin Lightning Charger Cable
Выберете то, что вам нужно
  1. How to fix a break in a Belkin Lightning Charger Cable, How to fix a break in a Belkin Lightning Charger Cable: шаг 1, изображение 1 из 1
    • Unplug the charger before starting with the repair.
    • Locate the damaged area on the charger.
  2. How to fix a break in a Belkin Lightning Charger Cable, Cut out the broken section: шаг 2, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Flush Cutter
    $29.99
    Купить
    • Cut out the part where the wire is broken using a pair of wire cutters.
  3. How to fix a break in a Belkin Lightning Charger Cable, Strip the cable: шаг 3, изображение 1 из 1
    Flush Cutter
    $29.99
    Купить
    • Strip off about 3cm of the black insulation with the wire strippers to expose the red and black wire on both parts of the cable.
    • You can use your flush cutters or a knife as an improvised wire stripper by cutting just enough so that you don't damage the small wires inside and pulling the insulation off.
    • Be safe when using the flush cutters or a knife: Pull away from your face and body when stripping wires.
  4. How to fix a break in a Belkin Lightning Charger Cable, Add Heat-shrink tubing: шаг 4, изображение 1 из 1
    • Slide about 1.75 of Heat-shrink tubing on a black and red wire each.
    • Slide about 5cm of Heat-shrink tubing on a charger cable.
  5. How to fix a break in a Belkin Lightning Charger Cable, Strip the wires: шаг 5, изображение 1 из 2 How to fix a break in a Belkin Lightning Charger Cable, Strip the wires: шаг 5, изображение 2 из 2
    Flush Cutter
    $29.99
    Купить
    • Strip off about 1cm of the insulation of each of the wires with the wire strippers.
    • You can use your flush cutters as an improvised wire stripper by cutting just enough so that you don't damage the copper strands inside and pulling the insulation off.
    • Wires are fragile, so when stripping be sure not to snip the wires.
  6. How to fix a break in a Belkin Lightning Charger Cable, Twist the wires together: шаг 6, изображение 1 из 1
    • Twist together the corresponding wires.
    • Be sure all wiring is bonded together.
    • Move the small heat shrinking tubes up to cover the exposed parts of the wires.
  7. Инструмент, используемый на этом этапе:
    Heat Gun
    $24.99
    Купить
    • Evenly heat the tubing with a heat gun. Make sure the tube is properly shrinking.
    • The tubing gets hot—hold the cord at the end of each side.
  8. How to fix a break in a Belkin Lightning Charger Cable, Move the Heat-shrink tubing up: шаг 9, изображение 1 из 1
    • Move the large heat shrinking tube up to cover the wires.
  9. How to fix a break in a Belkin Lightning Charger Cable, Heat the Heat-shrink tubing: шаг 10, изображение 1 из 1
    Heat Gun
    $24.99
    Купить
Заключение
Happy fixing!
Marcus Watson
Участник с: 04/11/19
157 Репутация
1 руководство автора
Команда
Eastern Washington University, Team S25-G1, Crane Spring 2019 Участник Eastern Washington University, Team S25-G1, Crane Spring 2019
EWU-CRANE-S19S25G1
4 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 18
За всё время: 1,196
