How to fix a dead FLIR ONE
Выберете то, что вам нужно
  1. How to fix a dead FLIR ONE, Open FLIR ONE: шаг 1, изображение 1 из 2 How to fix a dead FLIR ONE, Open FLIR ONE: шаг 1, изображение 2 из 2
    • Open the device with the opening tool in crack along top edge of back side.
    • Continue carefully opening the device around all four edges.
  2. How to fix a dead FLIR ONE, Separate the two halves: шаг 2, изображение 1 из 1
    • The two halves will separate very easily and the battery connector will detach very easily.
  3. How to fix a dead FLIR ONE, OPTIONAL - Check battery: шаг 3, изображение 1 из 1
    • OPTIONAL
    • Lay two pieces of 30 gauge solid insulated wire (wire-wrap wire) onto connector. Press into the two slots to make connections.
    • CAUTION - any wire or probe larger than 30 gauge is likely to damage the connector.
    • Use a multimeter to check the battery voltage, it should be about 3.7 V.
  4. How to fix a dead FLIR ONE, Reconnect battery: шаг 4, изображение 1 из 1
    • Carefully reconnect the battery. The two halves of the connector press together easily when properly aligned.
  5. How to fix a dead FLIR ONE, Reassemble: шаг 5, изображение 1 из 1
    • Press the two halves of the case together. You might see the LED in the button light or start blinking!
  6. How to fix a dead FLIR ONE, Done: шаг 6, изображение 1 из 1
    • Charge the device. A blinking LED indicates charging, a steady LED indicates done.
    • When charged, reconnect device to phone and try it!
    • You may get the message "Camera Files Not Received. Camera files could not be read, temperature accuracy and MSX alignment may be degraded." This is apparently a bug in some versions of the FLIR ONE App.
Финишная черта
20 человек успешно провели ремонт по этому руководству.
Frank Demarest
Участник с: 10/17/17
803 Репутация
1 руководство автора
25 Комментариев
Totally worked for mine! I almost gave up on it after seeing the YouTube video of the guy smashing his with a hammer. In addition I used a little bit of stablilant 22 contact enhancer product. Thanks Frank!
Todd - Ответить
Cool you shared this info with other folks!
Worked for my Android device!
Dmitry G.L. - Ответить
I can easily find a 185mAh battery but not a 350mAh. Not sure if anyone knows why its shrunk?
185 seems to work fine though.
Great guide. Sooooo easy.
georgedavies@hotmail.com - Ответить
I’m just wondering the same thing : why is there only 185 mAh batteries, with the same model number, and no 350 mAh available online
matthieuv -
Same. Just going to go with the 185. If the battery life is too short, I've had luck (with the current completely dead battery) with plugging it into a small usb powerbank.
gim -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 4
За последние 7 дней: 43
За последние 30 дней: 170
За всё время: 41,111
