Введение
Do you have a pocket that is just not sitting right? It's flimsy and opens up? A long time ago, my grandma showed me this easy trick!
Note: Please wear a thimble on whatever finger you need to protect.
Выберете то, что вам нужно
Select an appropriate sewing thread, depending on the fabric: try to match the color and the thickness.
Tread the sewing thread through the needle threader, and pull the needle threader.
Start from the inside of the pocket.
Pull the needle through the top edge of the pocket.
Try to have small and uniform stitches as possible.
Try not to catch the front side of the pocket fabric.
Pull the thread so that it tightens. Make sure you do not create any creases on the fabric.
At the end of the sewing thread, create a knot and cut the excess thread.
And Voila! - Your pocket is now fixed! Also after ironing, it will look much better.
This simple technique can be used on any types of pockets, also on jackets and pants.
Еще один человек закончил это руководство.
