Введение
Outline what you are going to teach someone how to do.
Выберете то, что вам нужно
Unscrew the four Torx screws from the backplate.
The backplate may begin to separate from the keypad face. Do not try to remove it yet.
The screws are T5 Torx screws, 5.6mm.
Remove the two Torx screws from below the cover.
These are T5 Torx screws, 8.6mm.
Gently work a spudger or a fingernail between the keypad face and the backplate.
Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
Note that only the bottom strut has a tab.
The screws are Phillips, 2.9mm
Tighten the four small Phillips screws.
The swivel assembly should now be less wobbly and loose, improving the function of the phone.
The screws are Phillips, 2.4mm.
Еще один человек закончил это руководство.
