How to fix alignment on an E-TKT Label Printer
Выберете то, что вам нужно
  1. How to fix alignment on an E-TKT Label Printer, Check the approximate alignment: шаг 1, изображение 1 из 2 How to fix alignment on an E-TKT Label Printer, Check the approximate alignment: шаг 1, изображение 2 из 2
    • Reboot the device.
    • After the splash screen the machine will home by rotating until the magnet meets the hall sensor.
    • Check the letter J position in the top window: If the letter is visually centered (second image), then you can skip ahead to to Step 3.
  2. How to fix alignment on an E-TKT Label Printer, Rough adjustment: шаг 2, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Turn off the device to avoid short circuiting the leads of the hall sensor.
    • Use blunt tweezers to finely adjust the hall sensor position along the tangential (cyan) axis as shown in the image:
    • If J is too much to the right, push the hall sensor toward the centre of the device (yellow arrow).
    • If J is too much to the left, pull the hall sensor towards yourself (magenta arrow).
    • Make sure to keep the same distance on the transversal (red) axis.
  3. How to fix alignment on an E-TKT Label Printer, Fine tuning: шаг 3, изображение 1 из 2 How to fix alignment on an E-TKT Label Printer, Fine tuning: шаг 3, изображение 2 из 2
    • Enter the web interface and click on SETUP.
    • Now press the TEST-button to the right side of ALIGN.
    • The machine will now slowly and lightly press the carousel letter, as shown in the second image.
    • Adjust the ALIGN-value until the press is fully centered on the character being pressed.
    • The align value ranges from 1 to 9, with 5 being the default (middle) value.
Заключение
Happy printing!
Sebastian
Участник с: 08/19/18
31 055 Репутация
Автор 71 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 19
За всё время: 243
