Введение
A dangling drawstring can mean the difference between enjoying the view and freezing your socks off in a high-altitude wind.
Fortunately, a loose drawstring is easy to fix. Keep yourself snug with this simple repair.
If you don't have a cotter pin, a safety pin works as well.
Выберете то, что вам нужно
Take the loose end of the drawstring, and cut any frayed material.
Take the cotter pin and thread the drawstring through the spilt end of the cotter pin.
Slide the drawstring to the eye of the cotter pin.
Scrunch the drawstring casing over the cotter pin and pull the cotter pin through the casing.
Continue scrunching and sliding the cotter pin through the casing.
Pull the cotter pin out through the end of the drawstring casing.
Pull the drawstring through, until the loose end of the drawstring comes out.
Insert the cotter pin—still holding the drawstring—into the drawstring hold.
Pinch the drawstring inside of the drawstring hold.
While holding the drawstring, pull the cotter pin out, sliding the drawstring out through the spilt in the pin.
While holding the drawstring in the hold, mark where the drawstring will be sewn with tailor's chalk.
Sew several passes along the chalk line, being sure to catch the drawstring.
2 участников успешно повторили данное руководство.
