How to fix autobody dents and cracks
Выберете то, что вам нужно
  1. How to fix autobody dents and cracks, How to fix autobody dents and cracks: шаг 1, изображение 1 из 2 How to fix autobody dents and cracks, How to fix autobody dents and cracks: шаг 1, изображение 2 из 2
    • Clean the area around the spot you wish to repair with water and if necessary, soap.
    • Always wear disposable gloves when working with Bondo. A painters mask and full length clothing is also recommended to help prevent breathing noxious fumes and skin irritation.
    • Mix the body filler and its hardener per the instructions on their containers.
  2. How to fix autobody dents and cracks: шаг 2, изображение 1 из 2 How to fix autobody dents and cracks: шаг 2, изображение 2 из 2
    • Fill the dent, gap or crack with the body filler and hardener mix. You can use paper, tape or your hands to smooth out the filler while it is still in putty form.
    • It is recommended that you apply several thinner layers of filler to deep dents and cracks to prevent having a porous finish.
    • It is recommended that you wipe off excess Bondo and smooth out the Bondo as much as possible before it dries to minimize the sanding required.
    • Once the Bondo has fully dried, typically around 20-30 minutes, sand the area so that it to the desired contour.
    • If the Bondo you bought isn't the color you want, follow our hand-painting guide to help match the color of your part.
Финишная черта
16 участников успешно повторили данное руководство.
Один комментарий
What grit sandpaper should be used for this? The article doesn't say.
Donna - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 25
За последние 7 дней: 168
За последние 30 дней: 716
За всё время: 41,304
