How to fix jumpy scroll wheel of a computer mouse
Выберете то, что вам нужно
  1. How to fix jumpy scroll wheel of a computer mouse, How to fix jumpy scroll wheel of a computer mouse: шаг 1, изображение 1 из 1
    • Flip the mouse upside down and remove the screw on the bottom of the mouse casing using a screwdriver
  2. How to fix jumpy scroll wheel of a computer mouse: шаг 2, изображение 1 из 1
    • Remove the wire from the board by slowly pulling the connector
  3. How to fix jumpy scroll wheel of a computer mouse: шаг 3, изображение 1 из 1
    • 1)Remove the board out of the case
    • 2)Slowly pull out the scroll wheel out of the encoder wheel well
  4. How to fix jumpy scroll wheel of a computer mouse: шаг 4, изображение 1 из 1
    • Slowly remove the metallic clamps from the plastic body to free the plastic case, holding the rotating mechanism .(If possible remover the metallic case fully from underneath the board, if it is not soldered)
    • Pull back or bend the plastic case a little bit for easy insertion of spring
    • Place a small coil spring on the extreme end of the small metallic plate holding the rotating mechanism against the plastic body
    • Pull the other end of the coil and place it on the other end where the scroll wheel is inserted
    • This will ensure that the small metallic plate and rotating mechanism are not loose thereby not causing a jumpy scroll wheel
  5. How to fix jumpy scroll wheel of a computer mouse: шаг 5, изображение 1 из 1
    • Now put this entire contraption inside the metallic case and close the metallic clamps
    • Inserted the scroll wheel into the wheel well and close up the mouse
Заключение
5 человек успешно провели ремонт по этому руководству.
Jithu Mohan
Участник с: 08/14/22
271 Репутация
1 руководство автора
3 Комментарии к руководству
quel est la taille du resort qu'on doit acheter pour la réparation
chosela - Ответить
Ottima guida come sempre! Complimenti
Paolo Galimberti - Ответить
Excellent et si la souris est hors de cause penser à éteindre et rallumer le PC.
Jean-Marie Villez - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 34
За последние 7 дней: 195
За последние 30 дней: 836
За всё время: 36,383
