Введение
When playing Video Games, every button on your controller has a purpose and a function. Without one of the buttons, your game-play is incomplete and sometimes impossible. Unfortunately, the Nintendo Joy-Cons are notorious for jammed ZR and ZL triggers. This can be annoying, but it's an easy fix. Follow these steps, and your Joy-Con will be fully operational in no time at all
Выберете то, что вам нужно
Using the Tri-Point Screwdriver, remove the 4 screws keeping the Joy-Con's shell together.
Use tweezers to lift the ZL button, then put it back into it's correct position
Put the button in a position where clicking is possible
Using the Tri-Point screwdriver, put the 4 screws back into place.
Congratulations, you did it!
4 участников успешно повторили данное руководство.
