Введение
The MNT Reform keyboard firmware is available in the reform2-keyboard-fw folder of the Reform repository.
Before starting, on your Reform, download it:
git clone git@source.mnt.re:reform/reform.git
Navigate to the keyboard firmware folder:
cd reform/reform2-keyboard-fw/
And compile it:
make
Выберете то, что вам нужно
Remove the following screws securing the keyboard frame to the main box:
Six black M2×5mm countersunk Philips screws
Lift the top of the keyboard frame and pull it out towards the screen.
Your Reform should now look like this.
Using a spudger or your fingernail, set the SW84 switch to ON.
Connect an external USB keyboard.
Copy the ./flash.sh command followed by a new line in your text editor, so that you can paste it and run it without the use of a keyboard.
Press the SW83 reset button, located right under the DIP switch from the previous step.
To reassemble your device, follow steps 1 and 2 in reverse order.
Еще один человек закончил это руководство.
