Введение
If the phone has a Screen Pattern, PIN lock and you haven't installed Google account on it you have to factory / master reset it to bypass the security.
This will erase all your personal information!!!
Видео обзор
Remove the battery for a while.
Press and hold simultaneously the Volume Down and the Power button.
Use the volume Up / Down buttons for a movement and the Power button for select.
Select "FACTORY RESET". The phone will restarts.
Did you do it successfully?
6 участников успешно повторили данное руководство.
2 Комментариев
very good trick it works great thanks
