Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Connect your iPod in normal mode (iTunes/file transfer).
Download the Rockbox EXE file at the link below. Run the Rockbox EXE file and click OK through the dialogues.
Once you are at this screen, click "Show disabled targets" and click OK at the dialogue.
After you have enabled the disabled targets, click the "Autodetect" button and your iPod's model should be highlighted in the menu above.
After you have selected your iPod's model, click OK.
Check all of the boxes selected in the blue box.
After checking all of the boxes that are necessary, click install.
Check the bootloader checkbox.
Click install again.
When this message appears in the console, press and hold both the MENU and the SELECT button until there is a message in the console telling you to release the buttons.
20 участников успешно повторили данное руководство.
15 Комментариев
Rockbox failed to install on mine. I followed every step but never got the message to press and hold select and menu for the bootloader. It said it had installed sucessfully but when it booted up I just got error -3. I put it in disc mode and deleted the software but it didn’t put it back to factory settings. Tried to install again but got the same thing except it said bootloader was already installed when I tried the last step. I’m afraid it is now bricked. :(
From my experience if you run into trouble like that youll need to detete the MBR (master boot record) then delete all partitions. Next you create a new Fat32 Partition and finally you will Format the Partition also as Fat32 all I use is AOMIE Partition Assistant and its FREE. Then Apple iTunes will detect it soon as you start your ipod and plug in to computer, will be detected as an iPod in recovery mode. From there I think you know the rest from there. I hope that helped even if a little to late for supper. Lol
Ms. Danielle Rae
Hi,
I am running rockbox release 15e1f592D-170118 on my Ipod Classic 7th gen. Soundwise should I look for a newsest release
also would you know at which frequency and range works the Rockbox ‘‘bass’’ setting
Thanks a lot
Denis
I tried to install Rockbox onto my iPod Classic 160GB, and I got no results , as a matter of fact; I got negative results asuch as I am not able to restore my iPod Classic in iTunes on my Mac, and I can’t listen to any of my music on the device, even though it appears as though my music is still there. Please help 911 because this is one of my favorite Apple devices of all time!
How do i uninstall rockbox and restore my ipid?
