Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
If you purchased a Xbox Wireless Receiver for Windows and are wondering how to use it in Windows 8.x, this guide will show you how to install the drivers. Since Microsoft is pushing Windows 10 as hard as they need to (despite many users not wanting it or preferring to wait), problems like this will come up.
Since Microsoft wants to make this as hard as possible on Windows 7/8.x users, this guide will show you how to manually install the driver and get it working. IMPORTANT: While the screenshots show Windows 7, I will not be assisting with Windows 7 driver installs after 1/14/2020.
*WARNING: WINDOWS 7 IS END OF LIFE AS OF 1/14/2020. NO SUPPORT FOR 7 SYSTEMS WILL BE PROVIDED. This procedure will work, but it is entirely unsupported at this point in time.
Guide notes
  • In most cases, the receiver will pick up the driver correctly, but needs encouragement. However, I have included manual installation instructions for situations where this does not happen.
  • Windows 10 users: Refer to the Windows 10 guide.
  1. Plug your Xbox Wireless Receiver into your PC. Before ging further into this guide, see if the driver installs automatically. If it does not, continue reading this guide. Plug your Xbox Wireless Receiver into your PC. Before ging further into this guide, see if the driver installs automatically. If it does not, continue reading this guide.
    • Plug your Xbox Wireless Receiver into your PC. Before ging further into this guide, see if the driver installs automatically. If it does not, continue reading this guide.
  2. Try this method first. Mircrosoft has pulled the driver from the public Update catalog. Before opening Device Manager, see if it installs automatically. If this does not work, the driver will need to be installed manually.
    • Try this method first. Mircrosoft has pulled the driver from the public Update catalog.
    • Before opening Device Manager, see if it installs automatically. If this does not work, the driver will need to be installed manually.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Open Device Manager. The best method varies by version of Windows. Windows 7: To open Device Manager in Windows 7: Open the start menu and right click Computer. Select Manange and locate Device Manager. Windows 8.x: Right click the Windows logo in the taskbar. Select Device Manager.
    • Open Device Manager. The best method varies by version of Windows.
    • Windows 7: To open Device Manager in Windows 7: Open the start menu and right click Computer. Select Manange and locate Device Manager.
    • Windows 8.x: Right click the Windows logo in the taskbar. Select Device Manager.
    • Double click XBOX ACC and verify you get a Code 28 error. Click Update Driver and try Search automatically for updated driver software.
  5. Refer to the guide comments for WIndows 7/8.x 32-bit .cab files. If the automatic installation does not work, download the driver from a Microsoft Update Catalog backup (64-bit only). Use this file as-is or unzip it with 7Zip.
    • Refer to the guide comments for WIndows 7/8.x 32-bit .cab files.
    • If the automatic installation does not work, download the driver from a Microsoft Update Catalog backup (64-bit only). Use this file as-is or unzip it with 7Zip.
    • Select Browse my computer for driver software.
    • Locate the folder where the driver is downloaded, and select Copy address as text. Paste the location into the box under Search for drivers in this lcoation:. Click Next.
  6. To verify the driver was installed correctly, check under Network Adapters. If the driver was installed correctly, it will show up here.
    • To verify the driver was installed correctly, check under Network Adapters. If the driver was installed correctly, it will show up here.
Заключение
2 участников успешно повторили данное руководство.
Nick
Участник с: 10.11.2009
54 516 Репутация
Автор 39 руководств
Команда
Master Techs Участник Master Techs
Community
292 членов
Автор 835 руководств
Комментариев: 18
I assume this does not work with the new version of the dongle
Jason Douglas - Ответить
The small one only works in Windows 10. The fat one works in 7/8.x and 10. There is a dedicated W10 guide with a warning related to drivers.
Nick -
Thank you. It's a shame. Such intentional and shady practices from Microsoft, blockade on a driver. You seem to really know your stuff… do you know if the Windows 10 dongle has features the old one does not? Since I don't even need to google it to know the old dongle is no longer for sale outside of second-hand.
Not that I'm aware of.
I can still find the old one new so it's available. I doubt it's discontinued.
Nick -
I know this post is old… but I found it to be of the only help so far…
I got hung up on Step 4. Can you please explain in detail how to “Locate the folder where the driver is downloaded, and select Copy address as text. Paste this location into the box under Search for drivers in this location: “ ? I have literally tried everything and couldn’t get to that point. I am still getting Windows was unable to install your XBOX ACC Windows could not find driver software for your device. If you know the manufacturer…blah blah blah etc etc.
Larry G - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 19
За последние 7 дней: 96
За последние 30 дней: 437
За всё время: 22,108
