Введение
A sharp object or wear went through the fabric of one of your favorite clothes?
Do not panic ! With a little equipment and at least as much patience, the hitch will be mended quickly and almost invisible.
Read carefully and follow the instructions for ironing the garment and the instructions for use of the thermo-adhesive fabric. This will prevent you from burning the fabric or canvas.
Выберете то, что вам нужно
To mend a hitch, you only need a few accessories: thermo-sticky cloth, an iron, wire, a needle, a pair of scissors and ... a little patience!
It is better to wash the piece of clothing first. Thus, the glue will adhere better to the fabric.
Iron the hole to flatten the edges and cut any excess wires to get clean, sharp edges.
The canvas is now glued, but to make sure it does not peel off after a few washes, it is better to sew the edge to the fabric.
Thread the thread on a needle and tie a knot at the end.
Starting from the wrong side of the fabric (so that the knot does not appear), sew the needle on both sides of the fabric along the edge of the piece of fabric.
Once arrived at the end, make a knot again and cut the excess thread. There you go ! We see almost nothing!
Admire your work and put on your favorite skirt / pants / shirt / tee shirt!
3 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
