How to mod the case of a USB Rubber Ducky for a squeeze-to-press button
Выберете то, что вам нужно
  1. How to mod the case of a USB Rubber Ducky for a squeeze-to-press button, Remove the metal sheath: шаг 1, изображение 1 из 1
    • First remove the the USB-C cap
    • Jam a flat object, such as your fingernail or a small screwdriver, in between the metal sheath and the Ducky on both sides.
    • Remove the metal sheath by pulling it off the Ducky.
  2. How to mod the case of a USB Rubber Ducky for a squeeze-to-press button, Open the case: шаг 2, изображение 1 из 2 How to mod the case of a USB Rubber Ducky for a squeeze-to-press button, Open the case: шаг 2, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    iFixit Opening Picks (Set of 6)
    • Carefully separate the top and bottom plastics by inserting a plastic pick at the seam.
    • The top and bottom are held together with matching ports and posts.
  3. How to mod the case of a USB Rubber Ducky for a squeeze-to-press button, Apply the spacer stickers: шаг 3, изображение 1 из 1
    • "Rain-drop" sticker cutouts can be found along the right side of the included sticker sheet. If you lost your sticker sheet, cut out a sticker of the appropriate size from any label paper or masking tape you have on hand.
    • Apply two to four layers of the sticker on the inside of the case, directly opposite the button.
    • The more layers you apply, the easier it will be to press the button. Start with 2-3 layers, then adjust to your preference through testing.
Заключение
Sebastian
Участник с: 08/19/18
28 100 Репутация
Автор 71 руководств
Команду
German Translators Участник German Translators
Community
35 членов
Автор 1 209 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 9
За последние 30 дней: 33
За всё время: 1,027
