How to open the chasis of Cisco 878 Integrated Services Router
Выберете то, что вам нужно
  1. How to open the chasis of Cisco 878 Integrated Services Router, Remove the two screws on back side: шаг 1, изображение 1 из 3 How to open the chasis of Cisco 878 Integrated Services Router, Remove the two screws on back side: шаг 1, изображение 2 из 3 How to open the chasis of Cisco 878 Integrated Services Router, Remove the two screws on back side: шаг 1, изображение 3 из 3
    • Only trained and qualified personnel should be allowed to install, replace, or service this equipment!
    • During this procedure, wear grounding wrist straps to avoid ESD damage to the card. Do not directly touch the backplane with your hand or any metal tool, or you could shock yourself!
    • Make sure that the power switch is turned to standby and that the power supply cable is disconnected. Disconnect all cables from the router back panel.
    • Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
  2. How to open the chasis of Cisco 878 Integrated Services Router, Remove top cover: шаг 2, изображение 1 из 3 How to open the chasis of Cisco 878 Integrated Services Router, Remove top cover: шаг 2, изображение 2 из 3 How to open the chasis of Cisco 878 Integrated Services Router, Remove top cover: шаг 2, изображение 3 из 3
    • 1. Gently push the top cover of the router away from you.
    • 2. Lift it up top cover from the bottom of the router.
    • 3. Remove top cover from the device.
    • Place the router bottom on an antistatic mat.
  3. How to open the chasis of Cisco 878 Integrated Services Router, Remove the three screws on front side: шаг 3, изображение 1 из 2 How to open the chasis of Cisco 878 Integrated Services Router, Remove the three screws on front side: шаг 3, изображение 2 из 2
    • Use the Phillips #1 Screwdriver to remove the three screws on front side of the device.
  4. How to open the chasis of Cisco 878 Integrated Services Router, Remove the inner metal shield: шаг 4, изображение 1 из 3 How to open the chasis of Cisco 878 Integrated Services Router, Remove the inner metal shield: шаг 4, изображение 2 из 3 How to open the chasis of Cisco 878 Integrated Services Router, Remove the inner metal shield: шаг 4, изображение 3 из 3
    • 1. Gently lift up inner metal shield from the bottom of the router.
    • 2. Remove inner metal shield from the device (see the anchors on the picture).
    • Be careful and do not distort the plates!
Заключение
Еще один человек закончил это руководство.
Jiri Altman
Участник с: 05/03/16
1 512 Репутация
Автор 9 руководств
Команда
4k20 Repair Team Участник 4k20 Repair Team
Community
2 членов
Автор 17 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 358
