How to re-caulk a bathroom sink
Выберете то, что вам нужно
  1. How to re-caulk a bathroom sink, Caulk seal: шаг 1, изображение 1 из 1
    • Clean and dry around the rim of the sink with a paper towel.
    • Make sure the old caulk is completely dry before moving on.
  2. How to re-caulk a bathroom sink: шаг 2, изображение 1 из 1
    • Remove the old caulk around the rim of the sink with a utility knife.
  3. How to re-caulk a bathroom sink: шаг 3, изображение 1 из 1
    • Remove any old caulk residue around the rim of the sink with a wet paper towel.
    • Then dry the area completely.
    • Ensure the area is completely clean and dry before applying the new caulk.
  4. How to re-caulk a bathroom sink: шаг 4, изображение 1 из 3 How to re-caulk a bathroom sink: шаг 4, изображение 2 из 3 How to re-caulk a bathroom sink: шаг 4, изображение 3 из 3
    • Apply painter's tape around the rim of the sink while leaving a small gap for caulk to be applied.
  5. How to re-caulk a bathroom sink: шаг 5, изображение 1 из 2 How to re-caulk a bathroom sink: шаг 5, изображение 2 из 2
    • Place the caulk tube into the gun.
    • Slowly press the trigger to release a thin line of caulk and move around the edge of the sink as you go.
  6. How to re-caulk a bathroom sink: шаг 6, изображение 1 из 3 How to re-caulk a bathroom sink: шаг 6, изображение 2 из 3 How to re-caulk a bathroom sink: шаг 6, изображение 3 из 3
    • Smooth out the caulk against the edge of the rim and counter with your wet index finger.
    • Keep a rag nearby to wipe excess caulk from your finger periodically.
    • Press against the caulk firmly while sliding your index finger as you go around the rim of the sink.
  7. How to re-caulk a bathroom sink: шаг 7, изображение 1 из 3 How to re-caulk a bathroom sink: шаг 7, изображение 2 из 3 How to re-caulk a bathroom sink: шаг 7, изображение 3 из 3
    • Pull the tape away from the counter immediately after applying the caulk.
    • Pulling away from the counter will help keep the caulk in a straight line.
  8. How to re-caulk a bathroom sink: шаг 8, изображение 1 из 1
    • Wipe off any excess caulk from the edge of the rim with a wet paper towel.
  9. How to re-caulk a bathroom sink: шаг 9, изображение 1 из 1
    • Let the new caulk dry for at least a day before using the sink.
Финишная черта
Еще один человек закончил это руководство.
Thi Nguyen
Участник с: 04/29/20
201 Репутация
1 руководство автора
Команда
UW Tacoma, Team S1-G43, Cardinal Spring 2020 Участник UW Tacoma, Team S1-G43, Cardinal Spring 2020
UWT-CARDINAL-S20S1G43
1 член
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 38
За последние 30 дней: 166
За всё время: 4,717
