Введение
Kwikset key-in-knob locksets are one of the most readily available door locksets on the market. This guide will show you how to re-key (or re-pin) them yourself without needing to call a Locksmith.
Moreover, many of the techniques contained within this guide can be applied to other brands and door lock models as well!
Инструменты
Запчасти
  1. Start by removing the lockset from the door, or packaging. Separate and set aside the interior half of the lockset.
    • Start by removing the lockset from the door, or packaging. Separate and set aside the interior half of the lockset.
    • Hold the lock so that the side with the keyway is facing directly away from you.
    • Locate the driver bar on the back of the exterior, or keyed, half of the lockset. It is the long cylindrical post that protrudes from the back of the lock and is hollow on the end.
    • Insert the cylinder removal tool into the end of the driver bar and turn until the tab (circled red) is in the twelve 'o clock position.
  2. Turn the lock so that the keyway faces the ground.
    • Turn the lock so that the keyway faces the ground.
    • Directly underneath the driver bar is another tab (circled red) just above one of the threaded posts.
  3. Using the edge of the cylinder removal tool, depress the tab from step 2 while removing the driver bar.
    • Using the edge of the cylinder removal tool, depress the tab from step 2 while removing the driver bar.
    • You should be able to pull the driver bar right out by hand. If it doesn't come out easily, here are a few tips:
    • Make sure the tab from step 1 is completely vertical and pointing towards one of the threaded cylinders. It can easily shift out of position, preventing removal of the driver bar.
    • Rotate the entire assembly 180 degrees so that the keyway faces the ceiling. While depressing the tab from step 2, wiggle the entire lockset. The driver bar should slide right out.
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. With the driver bar removed, insert the forked end of the cylinder removal tool into the back of the lock.
    • With the driver bar removed, insert the forked end of the cylinder removal tool into the back of the lock.
  6. Gently pushing the end of the cylinder removal tool into the back of the lock should dislodge the cylinder from the rest of the lock.
    • Gently pushing the end of the cylinder removal tool into the back of the lock should dislodge the cylinder from the rest of the lock.
  7. Use the forked end of the cylinder removal tool to remove the c-clip from the back of the plug.
    • Use the forked end of the cylinder removal tool to remove the c-clip from the back of the plug.
  8. With the c-clip removed, insert the key that currently operates the lock and use it to turn the cylinder plug 90 degrees.
    • With the c-clip removed, insert the key that currently operates the lock and use it to turn the cylinder plug 90 degrees.
    • Do not pull on the key!
    • Use a plug follower to gently push the plug out of the cylinder from the back, as pictured.
  9. To rekey the cylinder, simply dump the bottom pins out of the plug and replace with the appropriate sized pins for the new key.
    • To rekey the cylinder, simply dump the bottom pins out of the plug and replace with the appropriate sized pins for the new key.
    • Although not necessary, a key gauge can make identifying the correct pins much quicker.
    • Ensure proper operation by reinserting the plug into the cylinder and rotating it to the 9 'o clock and 3 'o clock positions, taking care to make sure the plug does not accidentally come out of the cylinder.
Заключение
9 участников успешно повторили данное руководство.
Jerry Orr
Участник с: 19.01.2012
758 Репутация
Автор 2 руководств
Комментариев: 4
Millions of Kwikset Smartkey Locks Vulnerable to Hacking, Say Researchers "Locks that are used in millions of homes and residential buildings worldwide and that are designed specifically to thwart hacking are easily opened with both a screwdriver and wire, two researchers say" what you recommend?
Ramon Melamed - Ответить
Wow, I had no idea it could be so easy! Re-keying a lock used to be so intimidating and seemed like it would take a long time and be expensive. But this looks like it makes it really simple and quick! Thanks so much for sharing, I'll have to try this!
http://www.andersonlockandsafe.com/resid...
89jackmoore - Ответить
I must say you have illuminate the complete process of Re-key. thanks for sharing this wonderful information.
Maisie Martha - Ответить
Thanks for explaining these steps for Lock re key, I really appreciate your efforts and wish you luck for more amazing work in the future.
Sienna Miller - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 19
За 7 дней: 114
За 30 дней: 418
За всё время: 37,866
