*Read guide note* How to rebuild a laptop CMOS battery
Выберете то, что вам нужно
  1. *Read guide note* How to rebuild a laptop CMOS battery, Determine what battery you need: шаг 1, изображение 1 из 2 *Read guide note* How to rebuild a laptop CMOS battery, Determine what battery you need: шаг 1, изображение 2 из 2
    • Most laptops use a CR2032 or 2025 cell. The CR2016 cell is uncommon.
    • Take the battery apart and check out what cell you need. This may be difficult depending on the wrap used.
  2. *Read guide note* How to rebuild a laptop CMOS battery, Disassemble the CMOS battery: шаг 2, изображение 1 из 3 *Read guide note* How to rebuild a laptop CMOS battery, Disassemble the CMOS battery: шаг 2, изображение 2 из 3 *Read guide note* How to rebuild a laptop CMOS battery, Disassemble the CMOS battery: шаг 2, изображение 3 из 3
    • If you break the leads, a new battery will need to be purchased.
    • After purchasing a battery, disassemble the CMOS battery. Use caution not to heavily bend the tabs. Too much damage may make them unusable.
    • Break the tabs off of the old battery. Dispose of based on your local laws.
  3. *Read guide note* How to rebuild a laptop CMOS battery, Verify polarity and tape the leads onto the new cell: шаг 3, изображение 1 из 3 *Read guide note* How to rebuild a laptop CMOS battery, Verify polarity and tape the leads onto the new cell: шаг 3, изображение 2 из 3 *Read guide note* How to rebuild a laptop CMOS battery, Verify polarity and tape the leads onto the new cell: шаг 3, изображение 3 из 3
    • ONLY USE ENOUGH TAPE FOR A FIRM HOLD. Using too much may short out the cell! In addition to using as little tape as possible, the cell must be tested before installation with a multimeter!
    • After the polarity has been matched, tape the positive lead to the new cell. To remove the risk of a failed rebuild, start on the + side and cut the tape to fit comfortably.
  4. *Read guide note* How to rebuild a laptop CMOS battery, Apply tape to the negative terminal: шаг 4, изображение 1 из 1
    • To place tape on the negative tab safely, try and keep the tape you cut as close as possible to the example image.
    • OFFSET the tape and terminal placement from the positive tab as much as possible.
    • After confirming the tape is not causing a short, add tape to the negative tab and tape down the negative terminal onto the new battery.
  5. *Read guide note* How to rebuild a laptop CMOS battery, Apply liquid electrical tape: шаг 5, изображение 1 из 3 *Read guide note* How to rebuild a laptop CMOS battery, Apply liquid electrical tape: шаг 5, изображение 2 из 3 *Read guide note* How to rebuild a laptop CMOS battery, Apply liquid electrical tape: шаг 5, изображение 3 из 3
    • Perfect coverage is not required. Focus on covering the major parts of the battery.
    • After verifying both leads are securely held onto the new cell, apply liquid electrical tape to the battery. 2-3 medium thickness coats are recommended.
Заключение
After building the replacement cell, install it in the notebook. Verify the battery works by setting the BIOS, powering it off and then removing the battery/AC adapter. If the CMOS memory is retained, your battery works.
7 участников успешно повторили данное руководство.
Nick
Участник с: 11/10/09
88 851 Репутация
Автор 49 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 528 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 11
За последние 7 дней: 109
За последние 30 дней: 510
За всё время: 20,387
