How to recover/reupholster WESC Maraca Headphone Ear Cushions
Выберете то, что вам нужно
  1. How to recover/reupholster WESC Maraca Headphone Ear Cushions, How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 1, изображение 1 из 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions, How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 1, изображение 2 из 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions, How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 1, изображение 3 из 3
    • Remove the cushion from the headphones by carefully pushing the edges out from the sides of the ear piece.
  2. How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 2, изображение 1 из 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 2, изображение 2 из 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 2, изображение 3 из 3
    • Use a marker to draw an arrow shape around the bottom of the cushion.
    • The arrow's point should fall toward the center of the cushion.
    • The points on the sides of the arrow should extend well beyond the edge of the cushion. They should not be aligned with the corners of the cushion.
    • This is done to ensure that there will be enough fabric to sufficiently cover the cushion.
    • The bottom of the arrow should line up with the sides and bottom of the cushion.
    • Repeat this step to draw a wider arrow for the side of the cushion.
  3. How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 3, изображение 1 из 2 How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 3, изображение 2 из 2
    • Cut out the two arrows of fabric.
    • Using the arrows as guides, cut out 3 additional arrows of each different size. In total you will have 4 top and bottom arrows and 4 side arrows.
  4. How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 4, изображение 1 из 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 4, изображение 2 из 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 4, изображение 3 из 3
    • Attach the tip of the arrow to the inside of the cushion and fold the rest of the arrow over the outside.
    • Using glue or sewing the arrow to the pad will result in a permanent fix, but if you make a mistake you may not be able to undo it.
    • Repeat this step to attach each arrow to the appropriate side of each cushion
  5. How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 5, изображение 1 из 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 5, изображение 2 из 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 5, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    Купить
    • Once you have all of the fabric attached, stretch the edges of the cushion back over the headphone's ear piece.
    • Use a thin plastic card to carefully tuck the edges of the cushion back into the ear piece.
  6. How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 6, изображение 1 из 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 6, изображение 2 из 3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: шаг 6, изображение 3 из 3
    • Once the cushion has been reattached to the ear piece, use the plastic card to carefully tuck the bottoms of the fabric arrows into the sides of the ear piece.
    • If there is too much fabric to tuck in, use scissors to remove the excess.
Заключение
Your headphones are now reupholstered and ready to use again.
5 участников успешно повторили данное руководство.
rss
Участник с: 02/24/15
274 Репутация
1 руководство автора
Команда
Cal Poly, Team 24-1, Green Winter 2015 Участник Cal Poly, Team 24-1, Green Winter 2015
CPSU-GREEN-W15S24G1
4 членов
Автор 4 руководств
Один комментарий
thanks for the idea! but I have to say this was a lot harder & less successful than promised, I’ve been at it for 1 hour and have only “reupholstered” 1 earphone… and it’s very partial (has holes). I rate my fixing result at 3/10, and I followed the instructions. :(
GYD - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 12
За последние 7 дней: 91
За последние 30 дней: 318
За всё время: 16,056
