Введение
If you spin your wheels and they stop right away, your bearings need to be cleaned and lubricated. Get your performance bearings back to performing with this guide. There are 7 quick and easy steps. The process should take about a half hour.
Выберете то, что вам нужно
Turn your wrench to the left to remove the wheel nut.
Take the wheel off of your trucks by pulling.
Take the bearing out of the gasoline and remove one side of the outside plastic locks by applying pressure on the inner ring and prying up.
Use your toothbrush to clean the bearings by using a gentle back and forth scrubbing motion.
Rinse the bearing with water and let dry for 5 minutes.
Once dry, pick up your bearings with two fingers and drop 2 drops of skateboard lubricant into the bearing.
Spin the bearings immediately to spread the lubricant evenly.
To reassemble your device, firmly put bearings back into your wheels and tighten them back down onto the trucks.
Еще один человек закончил это руководство.
