How to refurbish performance skateboard bearings
Выберете то, что вам нужно
  1. How to refurbish performance skateboard bearings, How to refurbish performance skateboard bearings: шаг 1, изображение 1 из 2 How to refurbish performance skateboard bearings, How to refurbish performance skateboard bearings: шаг 1, изображение 2 из 2
    • Turn your wrench to the left to remove the wheel nut.
    • Take the wheel off of your trucks by pulling.
    • Keep all nuts and spacers in separated, designated areas.
    • Wear gloves. You are working with messy materials such as gasoline.
  2. How to refurbish performance skateboard bearings: шаг 2, изображение 1 из 2 How to refurbish performance skateboard bearings: шаг 2, изображение 2 из 2
    • Firmly lever the bearing out using your screwdriver.
    • Do not be overly forceful to avoid scratching the bearing.
  3. How to refurbish performance skateboard bearings: шаг 3, изображение 1 из 1
    • Soak the bearing in a cup with premium gasoline for 5 minutes.
    • Soak each bearing separately so none are lost or dented.
  4. How to refurbish performance skateboard bearings: шаг 4, изображение 1 из 3 How to refurbish performance skateboard bearings: шаг 4, изображение 2 из 3 How to refurbish performance skateboard bearings: шаг 4, изображение 3 из 3
    • Take the bearing out of the gasoline and remove one side of the outside plastic locks by applying pressure on the inner ring and prying up.
    • Make sure you can clearly see and access the ball bearings.
  5. How to refurbish performance skateboard bearings: шаг 5, изображение 1 из 1
    • Use your toothbrush to clean the bearings by using a gentle back and forth scrubbing motion.
    • Rinse the bearing with water and let dry for 5 minutes.
  6. How to refurbish performance skateboard bearings: шаг 6, изображение 1 из 2 How to refurbish performance skateboard bearings: шаг 6, изображение 2 из 2
    • Once dry, pick up your bearings with two fingers and drop 2 drops of skateboard lubricant into the bearing.
    • Spin the bearings immediately to spread the lubricant evenly.
  7. How to refurbish performance skateboard bearings: шаг 7, изображение 1 из 3 How to refurbish performance skateboard bearings: шаг 7, изображение 2 из 3 How to refurbish performance skateboard bearings: шаг 7, изображение 3 из 3
    • Use a paper towel to remove excess lubricant.
    • Replace the plastic guard.
Заключение
To reassemble your device, firmly put bearings back into your wheels and tighten them back down onto the trucks.
Еще один человек закончил это руководство.
Luke Marshall
Участник с: 04/09/15
126 Репутация
1 руководство автора
Команда
Cal Poly, Team 30-2, Green Spring 2015 Участник Cal Poly, Team 30-2, Green Spring 2015
CPSU-GREEN-S15S30G2
4 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 21
За всё время: 5,879
