Введение
Sometimes - especially when swapped with a different device — the SIM card is not inserted correctly and will cause the device to not be able to retrieve network service or any saved information on the card. If that is not the case the SIM card may not be compatible with the device. To find that out you must call your cell phone provider.
The SIM card is located underneath the battery. For instructions on how to locate and remove the battery, see the guide for Phone Not Charging Properly.
The SIM card is help underneath a metal bracket. The SIM card must be slid out.
DO NOT FORCE IT OUT
There is a small, red plastic tab at the top of the card.
Slightly push down on the tab with one hand and slide the SIM card out with the other
Once the tab is pushed down, then you can add a little force. The key is to get the SIM card to slide out.
Examine your SIM card.
Check for damages such as warped plastic or burn marks.
If the SIM card is damaged it will not work
Use an alcohol wipe to clean the card
Use an air duster to clean where the SIM rests in the phone
Slide the card back in. Make sure the gold chip is faced down and that the cut corner is at the top left of the card.
If the device still shows an error you must get a replacement SIM card.
