Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
It is recommended to clean your Roomba every week (depending on how often you use it).
  1. Push down on the two yellow tabs, and pull open the brush gate gently Push down on the two yellow tabs, and pull open the brush gate gently Push down on the two yellow tabs, and pull open the brush gate gently
    • Push down on the two yellow tabs, and pull open the brush gate gently
  2. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  3. Grab and pull up on the brushes to remove them Use a damp microfiber or terry cloth to clean the rubber brush Use a damp microfiber or terry cloth to clean the rubber brush
    • Grab and pull up on the brushes to remove them
    • Use a damp microfiber or terry cloth to clean the rubber brush
  4. Use the included hair cutter to cut through hair that has gotten caught in the brush Slide the brush cleaner down and back up until your brush is clean Slide the brush cleaner down and back up until your brush is clean
    • Use the included hair cutter to cut through hair that has gotten caught in the brush
    • Slide the brush cleaner down and back up until your brush is clean
Заключение
Еще один человек закончил это руководство.
Matt Davis
Участник с: 22.01.2015
1 406 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 21-20, Maness Winter 2015 Участник Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 членов
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 21
За всё время: 1,973
