How to remove malware from an infected windows PC
Выберете то, что вам нужно
  1. How to remove malware from an infected windows PC, Install Anti-Malware software: шаг 1, изображение 1 из 2 How to remove malware from an infected windows PC, Install Anti-Malware software: шаг 1, изображение 2 из 2
    • On the PC you will be doing antivirus on, install the appropriate software. If the PC with malware does not turn on, install on a different one to do anti-virus.
    • Malwarebytes is great anti-virus software. Go to the website and install it for free.
    • Glarysoft Malware hunter is also good. Their website is here.
    • Other free anti-malware works too, but these are my favorites.
  2. How to remove malware from an infected windows PC, Remove your SATA HDD/SDD from the PC: шаг 2, изображение 1 из 1
    • This step only applies to PCs that do not boot. If the PC with malware runs, then install the software directly onto it.
    • Because assembly of different laptops and PCs vary so much, you will have to figure out or find a guide to remove your drive.
  3. How to remove malware from an infected windows PC, Connect the drive: шаг 3, изображение 1 из 1
    • This step also only applies to PCs that don't boot.
    • If your non-infected PC is a desktop, you may unplug the optical drive and plug the connections into the HDD or SSD. If it is a laptop, you will need a SATA to USB adapter.
    • Shut down your desktop before unplugging the DVD drive and attaching the HDD.
  4. How to remove malware from an infected windows PC, Disinfect your PC: шаг 4, изображение 1 из 3 How to remove malware from an infected windows PC, Disinfect your PC: шаг 4, изображение 2 из 3 How to remove malware from an infected windows PC, Disinfect your PC: шаг 4, изображение 3 из 3
    • Once you've installed the necessary programs and (if applicable) connected you're infected drive to you PC, you are ready to be the doctor.
    • Run Malwarebytes.
    • Run Glarysoft Malware Hunter.
    • Windows defender comes preinstalled with Windows. Use that also.
  5. How to remove malware from an infected windows PC, Double checking another PCs drive.: шаг 5, изображение 1 из 1
    • This is the last step for checking another PCs drive
    • Go into file explorer, right click on the drive from the infected PC, and select each of the highlighted options.
  6. How to remove malware from an infected windows PC, Finito!: шаг 6, изображение 1 из 1
    • All done! follow these instructions in reverse to put everything back.
Финишная прямая
38 человек успешно провели ремонт по этому руководству.
George A.
Участник с: 12/07/16
22 407 Репутация
Автор 4 руководств
Команда
Community Protectors Участник Community Protectors
Community
19 членов
Автор 26 руководств
1 Комментарий к руководству
changed “boot” to “turn on” because it would make more sense to the people who read this article, as they could be the much less computer-savvy people
aaaaaaaaaaaaaaaaa - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 38
За последние 30 дней: 179
За всё время: 10,588
