Введение
Some people might be afraid of breaking the vent to clean it up, but I got mines for free so you don't have to worry about breaking yours.
There are 4 tabs near the handle, so just use a flathead screwdriver to dig them out. Just don’t put too much force since it is made of plastic.
Выберете то, что вам нужно
I suggest starting from the middle, popping it out just a tiny bit and move outwards to the sides
Apply a small constant lift should make removing this easier. Similar to disassembling other plastic encasements.
It pulls towards you a little bit to loosen up and then comes out by moving it forward once it's in this position.
Clean the vent and reassemble by inserting it from the bottom first and then clicking in the tabs in the front.
Well that was easy wasn't it? Back to making it eat wildfire smoke and whatnot when the time comes.
Also do keep in mind that "PlasmaWave" is an ionizing tech which creates ozone in small amounts (regardless of what manufacturer says), so don't use it that often. If you do, you need to air out the room/house when the outside air is cleaner.
