Введение
Small tags on gloves, hats, and other accessories are easy to snap off by mistake - especially on kids items. But they're simple to fix back on, with the help of a sewing machine.
Выберете то, что вам нужно
Locate the broken tag, and find the area where it snapped off from
Often the cause of the breakage, is that the sewing thread tore through the tag, leaving frayed ends
Trim away any damaged or frayed ends of the tag
Use a "seam ripper" tool, or small scissors, to carefully remove the old thread from the item
Prepare your sewing machine in a clean location, and position the item underneath the needle. Depress the foot to secure the item in place.
Tip: for setting up a sewing machine, use the resource Thread a Sewing Machine
Make a short lock stitch, and then a straight line stitch from one side of the label to the other. Make a second stitch using the reverse lever, and one final stitch in the original direction. Finish with a locking stitch
Remove the item from the machine.
Carefully trim the thread on the outside...
... and on the inside
Check the repair and pull the label gently to test the durability
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
