How to repair a taped seam
Выберете то, что вам нужно
  1. How to repair a taped seam, Preparation: шаг 1, изображение 1 из 3 How to repair a taped seam, Preparation: шаг 1, изображение 2 из 3 How to repair a taped seam, Preparation: шаг 1, изображение 3 из 3
    • Identify the defective taped seam, and the extent of the damage. Is it only a small area peeling up, or something larger?
    • Note: We will be using a hot iron to re-weld the taped seam, so prepare a tidy area matching the size of your repair.
    • Lay a heatproof material underneath the item, such as an ironing board, or ironing board cover. Set the iron at 150 °C maximum.
  2. How to repair a taped seam, Prepare the hot-melt tape: шаг 2, изображение 1 из 3 How to repair a taped seam, Prepare the hot-melt tape: шаг 2, изображение 2 из 3 How to repair a taped seam, Prepare the hot-melt tape: шаг 2, изображение 3 из 3
    • Note: In this guide, we assume that the tape cannot be re-welded due to the glue being damaged or worn-out. But if you want to make as test first, move to the next step without adding extra thermo-tape.
    • Prepare the hot-melt tape by cutting a small piece to the same size as the defect. The tape should fit underneath the damaged tape, so that none is protruding out from the edges
    • Tip: we have used a common form of curtain tape here, as it is widely available; but more advanced tapes are also available from sewing/craft stores.
  3. How to repair a taped seam, Iron the taped seam: шаг 3, изображение 1 из 3 How to repair a taped seam, Iron the taped seam: шаг 3, изображение 2 из 3 How to repair a taped seam, Iron the taped seam: шаг 3, изображение 3 из 3
    • We will now use the head from the iron to melt the hot-melt tape in between the broken seam layers, to bond them together again.
    • Carefully check the tape is underneath the old taped seam and not protruding out from the edges. Position the heated iron on top of this area, and apply light pressure, for up to 10 seconds.
    • Let the area cool down, and then check whether the hot-melt tape has melted and bonded the defect successfully. If it has not, apply the iron again, and increase the pressure a little. Continue this process until it is fully glued down.
    • Tip: you may find in this process, that some extra hot-melt tape is needed in some areas. simply cut some more small pieces and slide them between the seam, and repeat the steps above.
  4. How to repair a taped seam, Finished and ready!: шаг 4, изображение 1 из 1
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Заключение
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Участник с: 07/19/23
10 230 Репутация
Автор 66 руководств
Команда
INTERSPORT Участник INTERSPORT
Community
25 членов
Автор 169 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 9
За последние 7 дней: 26
За последние 30 дней: 112
За всё время: 1,637
