Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
What is an oleophobic coating kit?
Modern smartphones feature an oleophobic (oil-repellent) coating that protects the screen, improves smoothness, and reduces fingerprints.
However, oleophobic coatings can degrade or wear off quickly, and you will notice a patch of the screen tends to get greasy or dirty with fingerprints more easily. Also, many screen protectors do not feature an oleophobic coating, making them get grubby with fingerprints and grease.
There is a simple solution to restore your oleophobic coating, or to add an oleophobic coating (e.g. iGlaco) to your screen or screen protector, to prevent fingerprints on your touchscreen. You can use an oleophobic coating kit.
Инструменты
Инструменты не указаны.
Запчасти
  1. Clean touch screen thoroughly to remove all fingerprints, smudges and grease.
    • Clean touch screen thoroughly to remove all fingerprints, smudges and grease.
  2. Keep the pad facing upwards. Gently press a tissue onto the top of the pad to release excess pressure.
    • Keep the pad facing upwards. Gently press a tissue onto the top of the pad to release excess pressure.
  3. Spread the liquid around the whole screen.
    • Spread the liquid around the whole screen.
  4. Wipe the liquid around the screen with a tissue until it disappears.
    • Wipe the liquid around the screen with a tissue until it disappears.
  5. DO NOT TOUCH the screen for at least 4 hours after coating. The longer you leave the screen, the more effective the coating will be.
    • DO NOT TOUCH the screen for at least 4 hours after coating. The longer you leave the screen, the more effective the coating will be.
    • TIP: Apply the coating before going to sleep, so it has all night to bond well.
  6. Remarks : Apply 2-3 COATS on different days to fully maximize oleophobic coating performance and film durability! Leftover residue on the touch screen after coating can be wiped off easily after 4-8 hrs by using tissue paper. Please do not remove them before completion of film bonding. Remarks : Apply 2-3 COATS on different days to fully maximize oleophobic coating performance and film durability! Leftover residue on the touch screen after coating can be wiped off easily after 4-8 hrs by using tissue paper. Please do not remove them before completion of film bonding.
    • Remarks : Apply 2-3 COATS on different days to fully maximize oleophobic coating performance and film durability! Leftover residue on the touch screen after coating can be wiped off easily after 4-8 hrs by using tissue paper. Please do not remove them before completion of film bonding.
  7. You can get Perfect Oleophobic Coating on your device !!
    • You can get Perfect Oleophobic Coating on your device !!
Финишная черта
123 участников успешно повторили данное руководство.
Ken Masaoka
Участник с: 07.07.2012
3 970 Репутация
1 руководство автора
Комментариев: 28
Very interesting guide. Awesome.
Do I have to remove the coating that is on the device when it's new?
Especially when the coating has some very small scratches?
And if yes, how to remove it?
Thanks
Peter Gordon - Ответить
I recommend avoiding this for the iPhone 6. The curved screen simply directs the liquid into the casing.
Alex Pappajohn - Ответить
Tried this with my iPhone 6. Seems to work pretty well. I'll do a few more quotes. I noticed this actually had a beneficial effect on screen scratches. Filled them in pretty well, blends with the screen more.
Talk about a happy accident!
ckeyser - Ответить
one comment says not to use it with iPhone 6 and another one says it worked ok, so what do I do? is it any dangerous? because I bought it before your last comments but I still havent used it since I'm worried about what can happen
Salvador Martinez -
I always have problems with my screen, sometimes I can't see anything on my LCD.
Praska - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 127
За последние 7 дней: 757
За последние 30 дней: 3,405
За всё время: 311,079
