Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
What is an oleophobic coating kit?
Modern smartphones feature an oleophobic (oil-repellent) coating that protects the screen, improves smoothness, and reduces fingerprints.
However, oleophobic coatings can degrade or wear off quickly, and you will notice a patch of the screen tends to get greasy or dirty with fingerprints more easily. Also, many screen protectors do not feature an oleophobic coating, making them get grubby with fingerprints and grease.
There is a simple solution to restore your oleophobic coating, or to add an oleophobic coating (e.g. iGlaco) to your screen or screen protector, to prevent fingerprints on your touchscreen. You can use an oleophobic coating kit.
Выберете то, что вам нужно
Clean touch screen thoroughly to remove all fingerprints, smudges and grease.
Keep the pad facing upwards. Gently press a tissue onto the top of the pad to release excess pressure.
250 участников успешно повторили данное руководство.
52 Комментариев
Very interesting guide. Awesome.
Do I have to remove the coating that is on the device when it's new?
Especially when the coating has some very small scratches?
And if yes, how to remove it?
Thanks
apply Acetone
Mudiver -
I recommend avoiding this for the iPhone 6. The curved screen simply directs the liquid into the casing.
Tried this with my iPhone 6. Seems to work pretty well. I'll do a few more quotes. I noticed this actually had a beneficial effect on screen scratches. Filled them in pretty well, blends with the screen more.
Talk about a happy accident!
one comment says not to use it with iPhone 6 and another one says it worked ok, so what do I do? is it any dangerous? because I bought it before your last comments but I still havent used it since I'm worried about what can happen
