How to repair the MagSafe Magnetic End
Выберете то, что вам нужно
  1. How to repair the MagSafe Magnetic End, How to repair the MagSafe Magnetic End: шаг 1, изображение 1 из 1
    • This is a hyper extended end of a magsafe. It is no longer working due to the wire having pulled apart.
  2. How to repair the MagSafe Magnetic End: шаг 2, изображение 1 из 1
    • Use wire cutters to cut the wire of the magsafe some distance back from the magnetic end. I cut about 4 inches back. You can get much closer like maybe an inch, as you will see in the next step.
  3. How to repair the MagSafe Magnetic End: шаг 3, изображение 1 из 1
    • I used a utility knife to cut the nice white cover off the tiny printed circuit board. There is a molded plastic cover similar to hot glue which had to be stripped off the PCB.
  4. How to repair the MagSafe Magnetic End: шаг 4, изображение 1 из 1
    • 1.) Take the good end of the existing wire and strip it.
    • 2.) The interior wire, which is coated in white should be soldered on a square metal plate about one eighth inch square. This plate is opposite a small chip for reference.
    • 3.) The braided wire coats the white interior wire, and is wrapped around it in two different directions. This wire should be peeled off and then twisted together.
    • 4.) Then solder it in place opposite the chip and the other wire.
  5. How to repair the MagSafe Magnetic End: шаг 5, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Electrical Tape in 6 Assorted Colors
    $7.99
    Купить
    • Plug in wall outlet and install on computer to test.
    • At this point there are still exposed live wires carrying DC voltage. To eliminate risk of shock or shorting, cover the bare wires in electrical tape, heat shrink tubing, or Sugru.
Заключение
21 участников успешно повторили данное руководство.
040304
Участник с: 11/05/09
9 814 Репутация
1 руководство автора
14 Комментариев
Thanks a lot for the tutorial, worked like a charm and the result is quite clean too. You made me save 80€!
Aurelie Aurelmaispasmarc - Ответить
Works but looks like !@#$.
Peter Mortensen - Ответить
If it looks stupid, but it works, then it's not stupid. I'm certain someone has the skill to make that end look good.
040304 -
Awesome! I had not used my macbook for almost a month, since my magsafe quit working. I was afraid to cut into the plug, fearing I might damage the circuitry inside. Once I saw the pictures of the inside of the adapter, I knew the correct way to do it. Thank you for the tutorial. :)
Reilly McGinnis - Ответить
Could you please make the same guide for a L connector?
luca - Ответить
I repaired my magsafe end and managed to back the white cover off and re-use it. I couldn't re-use the strain relief, but built up a facsimile using hot glue.
thathope2 - Ответить
How would this be done for the new Magsafe 2 connection? This is aluminum, and not plastic....help would be appreciated!
No Body - Ответить
Having bought a second one of these useless cables, I blue-tacked the connection in place and secured the cable along the side of the computer. Not pretty but at €90 a replacement, well worth it. You can also mould a pretty cover with Sugru.
brogamora - Ответить
Thanks. That gave me the courage to have a crack at it. Fixed it ok! Fortunately it was not necessary to open the intestines because only the (earth? neutral... well it was wire at least) around the core was worn out so I wacked a slither of copper across the 'break" and soldered it together. One thing bothers me though: Why do north Americans say 'sodder" rather than "solder"?
jcahill30 - Ответить
> ...only the ...wire.... around the core was worn out...
so i soldered it together and wacked a slither of copper across the 'break" and put electric-pvc-tape around..
got no ibook, is for a friend:
could someone with a working one check the voltages at the contacts: i only read around 3 volts..! is it defect??
-well the magnetic-part can have an electronic to check whether the adapter really is attached to the device and only then give 20v power-
biopilz - Ответить
correction: white electrical-pvc-tape around -very firmly-..
biopilz - Ответить
But, be careful; this might result in short circuit and burn the mother board of the laptop. My laptop is now dead, in this way..!
Albert Charles - Ответить
Thank you It's working again :)
avay48 - Ответить
Bonjour, peut on remplacer la pièce où vient s'émanter la prise magsafe 1? ( sur le macbook, pas sur le fil) Merci !
Ced - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 27
За последние 30 дней: 65
За всё время: 113,610
