Введение
If you notice that your bicycle tire is flat and re-inflating does not work or has a slow leak, you need to replace your bicycle tube. This guide will demonstrate the process and steps required to fix a worn or punctured bike tube on a Trek 800 model bicycle.
Инструменты
Запчасти
  1. Acknowledge that you have a flat tire.
    • Acknowledge that you have a flat tire.
    • Signs of a flat tire: deflated without rider. If the tire looks inflated, but deflates when sitting on the bicycle, it is not inflated enough. In general, the pressure should be at the maximum recommendation on the sidewall of the tire (less wear and drag, and reduces risk of puncture).
  2. Note the size of tube needed and optimum tire pressure. It is best to know this prior to purchasing a bicycle tube, as well as inflating the tube to the proper maximum pressure in the last step.
    • Note the size of tube needed and optimum tire pressure.
    • It is best to know this prior to purchasing a bicycle tube, as well as inflating the tube to the proper maximum pressure in the last step.
  3. Disengage the rear brake before you remove the rear wheel. Pinch the arms to compress the brake cable. Pull the cable out of the lever and it will fully release.
    • Disengage the rear brake before you remove the rear wheel.
    • Pinch the arms to compress the brake cable.
    • Pull the cable out of the lever and it will fully release.
    • If your brake does not have a quick release (as shown in the picture) you may have to loosen the nut securing the brake cable to open the brakes.
  4. Locate the skewer on the center of the wheel attached to the bicycle frame slots. Turn the skewer lever away from the bicycle.
    • Locate the skewer on the center of the wheel attached to the bicycle frame slots.
    • Turn the skewer lever away from the bicycle.
    • Turn the skewer cap counter clockwise.
    • Once it is loose enough you can pull the tire off, but do not pull it yet entirely off.
    • If your bike does not have a quick release for the wheel, you will need to unscrew the axle nut.
    • Some anti-theft gravity nuts require the bike to be upside down, others need a special wrench. However, you'll know if you have bought such an anti-theft device.
  5. Remove chain from sprocket.
    • Remove chain from sprocket.
    • Chain will usually be covered in grease or rust. Wear gloves or use a rag to avoid getting dirty when moving the chain.
  6. Pull tire and rim off of bike. Pinch the tire and separate from rim. A plastic tire lever can be useful.
    • Pull tire and rim off of bike.
    • Pinch the tire and separate from rim. A plastic tire lever can be useful.
  7. Pull out punctured tube from tire and replace with new tube.
  8. Put the tire with the new tube inside back on the rim. Inflate the tube slightly to make it easier to insert inside the tire prior to attatching the tire and tube combo back on the rim. Make sure the hole in the rim lines up with the valve on the tube properly.
    • Put the tire with the new tube inside back on the rim.
    • Inflate the tube slightly to make it easier to insert inside the tire prior to attatching the tire and tube combo back on the rim.
    • Make sure the hole in the rim lines up with the valve on the tube properly.
    • Avoid a missaligned valve. This can cause the valve to break internally as the rubber will be cut around the valve stem by the wheel where the valve portrudes from the rim.
  9. Re-attach rim to the bike frame in reverse order of removal. Make sure the chain aligns with the sprocket. Slide the quick-release skewer into the slots in the bike frame.
    • Re-attach rim to the bike frame in reverse order of removal.
    • Make sure the chain aligns with the sprocket.
    • Slide the quick-release skewer into the slots in the bike frame.
  10. Make sure skewer is completely inserted into the frame slots before tightening. Rotate the skewer cap clockwise and ensure a snug contact between the skewer caps and the frame slots. Rotate the skewer lever towards the bicycle frame.
    • Make sure skewer is completely inserted into the frame slots before tightening.
    • Rotate the skewer cap clockwise and ensure a snug contact between the skewer caps and the frame slots.
    • Rotate the skewer lever towards the bicycle frame.
    • If the skewer lever is too difficult to twist towards the frame, back off the skewer cap until you can twist the lever towards the bicycle frame and it feels snug.
  11. Re-attach the rear brake. Reference step 3 in reverse order.
    • Re-attach the rear brake.
    • Reference step 3 in reverse order.
  12. Inflate the tube to the specified pressure on tire sidewall (refer to step 2). Insert the tire pump head into the valve, and lock with lever on the pump head. This tire is inflated to a maximum pressure of 40 psi.
    • Inflate the tube to the specified pressure on tire sidewall (refer to step 2).
    • Insert the tire pump head into the valve, and lock with lever on the pump head.
    • This tire is inflated to a maximum pressure of 40 psi.
Заключение
If all of your steps were completed correctly you should be free to ride. Enjoy.
Ryen Simpson
Участник с: 24.02.2015
137 Репутация
1 руководство автора
Команда
Cal Poly, Team 23-2, Green Winter 2015 Участник Cal Poly, Team 23-2, Green Winter 2015
CPSU-GREEN-W15S23G2
4 членов
Автор 12 руководств
Один комментарий
Thanks for providing these instructions. But I think the most difficult step (getting the tire off the rim) should be explained in more detail.
Nils Faltin - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 28
За всё время: 2,284
