How to replace the screen on a patio door.
Выберете то, что вам нужно
  1. How to replace the screen on a patio door., Screen: шаг 1, изображение 1 из 2 How to replace the screen on a patio door., Screen: шаг 1, изображение 2 из 2
    • Remove screen door from the frame.
    • Disconnect any door closers or safety chains on the door.
    • Remove the screws holding the door to the aluminum frame located on the hinge side of the door.
    • You will need to check the type of screw head to identify the proper tools. I ended up needing a socket wrench for the hinge and a hammer for the door closure.
    • Carefully move the door into the work area for the next step.
    • The amount of screws and screw size/type will vary, so make sure you check the type of screw head before attempting to remove the door.
  2. How to replace the screen on a patio door.: шаг 2, изображение 1 из 1
    • Lay the door on a hard surface.
    • Make sure the side with the spine showing is face up.
  3. How to replace the screen on a patio door.: шаг 3, изображение 1 из 2 How to replace the screen on a patio door.: шаг 3, изображение 2 из 2
    • Remove spline by using an awl or pointed object. Pry the end up and pull the spline to remove it from the frame.
    • If the spine is in good shape (not brittle, dried out, or broken) and comes out intact, it may be carefully reused. Usually, you will need replace it.
  4. How to replace the screen on a patio door.: шаг 4, изображение 1 из 1
    • Remove the old screen fabric from the frame.
  5. How to replace the screen on a patio door.: шаг 5, изображение 1 из 1
    • Lay new screen on opening.
  6. How to replace the screen on a patio door.: шаг 6, изображение 1 из 1
    • Cut screen to a manageable size. (2 inches larger than the frame is ideal.)
  7. How to replace the screen on a patio door.: шаг 7, изображение 1 из 1
    • Tape or secure screen to prevent movement during spline installation.
  8. How to replace the screen on a patio door.: шаг 8, изображение 1 из 1
    • Run concave roller over the screen in the groove designed for the spline.
    • Pre-shape the screen into the channel so that the spline will go in willingly.
  9. How to replace the screen on a patio door.: шаг 9, изображение 1 из 2 How to replace the screen on a patio door.: шаг 9, изображение 2 из 2
    • Begin at a top corner and press the spline down over the screen fabric and into the groove on the frame using the convex roller.
  10. How to replace the screen on a patio door.: шаг 10, изображение 1 из 1
    • Trim off the excess spline using a razor blade.
    • Make sure you are careful and do not puncture the screen.
  11. How to replace the screen on a patio door.: шаг 11, изображение 1 из 2 How to replace the screen on a patio door.: шаг 11, изображение 2 из 2
    • Trim the extra screen material flush at the edge of the retaining spline with a razor blade, creating a neat appearance.
    • Take extra care that you do not cut the screen on the inside of the spline.
  12. How to replace the screen on a patio door.: шаг 12, изображение 1 из 1
    • Reinstall the door reversing the process of Step 1.
  13. How to replace the screen on a patio door.: шаг 13, изображение 1 из 1
    • The job is done, and the screen door looks great.
Заключение
Replacing your screen on your door is a simple process that can be knocked out in an hour’s time depending on how handy of a person you are. Making this fix helps ensure you can enjoy the fresh out while keeping bugs out!
Еще один человек закончил это руководство.
Jessica Bowers
Участник с: 01/26/20
247 Репутация
1 руководство автора
Команда
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 Участник USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020
USFSM-STEWART-S20S1G1
23 членов
Автор 27 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 31
За последние 30 дней: 141
За всё время: 2,561
