Введение
If your dryer is running too hot, not heating at all, or displaying error codes, a faulty temperature sensor could be the cause. This guide will show you how to replace the temperature sensor to restore proper function.
⚠️ Always unplug your dryer before starting any internal repairs.
Выберете то, что вам нужно
Шаг 2 Identify faulty temperature sensor
Clothes remaining damp or coming out overdried despite the chosen program indicates an inaccurate temperature reading.
Confirm all ducts, filters, and channels are clean to rule out airflow restrictions.
A small, low‑cost temperature sensor often causes these drying issues when it stops reading correctly.
Шаг 3 Remove condenser container
Slide the water condensation container completely out of its front‑panel slot.
Шаг 4 Undo screws inside container cavity
Remove the two plastic‑thread screws located deep inside the container recess with a manual screwdriver.
Шаг 5 Loosen rear mounting screws
Unscrew the two rear panel screws by hand where a power driver cannot fit.
Lift the rear plate slightly and pull it downward to release it from the frame.
Шаг 6 Remove side panel screws
Take out the single corner screw at the top edge of the side panel.
Remove the four visible screws along the panel face.
From underneath, remove the four screws securing the lower edge of the panel.
Шаг 7 Detach service side panel
Tilt the loosened panel outward from the rear, raise it slightly, and lift it away to expose the service side.
Шаг 8 Locate the temperature sensor
Find the small probe seated in a rubber grommet along the exhaust air path on the service side.
Шаг 9 Disconnect and remove the sensor
Grip the sensor body and pull it straight out of the rubber mount.
Unplug the two quick‑connect wires from the sensor terminals.
Шаг 10 Install the new sensor
Push the replacement sensor fully into the rubber mount until seated.
Reattach the two wires to their respective terminals.
Шаг 11 Reassemble the dryer
Refit the side panel, aligning tabs and lowering it into place before tightening all previously removed screws.
Reinstall the rear plate and secure the two screws.
Insert the water condensation container back into its slot.
Once the sensor is replaced, plug your dryer back in and run a test cycle to ensure it heats properly and no error codes appear.
With the new temperature sensor in place, the dryer can accurately monitor exhaust air temperature and stop at the desired dryness level. Continue to keep filters and ducts clean to avoid future sensor strain, and always follow manufacturer maintenance schedules.
1 Комментарий к руководству
Temperature problem could also be caused by faulty Temperature selector switch
eg dryer heat is OK on low and medium selectio, but no heat is available on high selection.
