How to reset the password on a Mac
  1. How to reset the password on a Mac, Start your Mac in Single-User Mode: шаг 1, изображение 1 из 1
    • Shut down your Mac
    • Press and hold the Command + S keys while pressing the power button to turn on your Mac.
    • It is best to start holding the keys before the screen turns on or you hear the startup chime. If you see the Apple logo, then you need to shut down and to do this step over. Except on a Mac with a T2 chip, the Apple logo will always appear the second the computer turns on.
    • You should see a black screen with white text.
  2. How to reset the password on a Mac, Mount root device as read-write: шаг 2, изображение 1 из 1
    • When the text stops, you should see a line that says "localhost:/ root#" at the bottom. If you don't see "localhost:/ root#", press enter.
    • Type in "mount -uw"
    • Some more text will appear on the screen. when you see the "localhost:/ root#"at the bottom, continue to the next step
  3. How to reset the password on a Mac, Remove the .AppleSetupDone file: шаг 3, изображение 1 из 1
    • Type in, "rm /var/db/.AppleSetupDone" and press enter/ return
    • This is case sensitive!
    • There must be a space in between the rm and / otherwise you will get a "no such file or directory" error
    • This method WILL NOT work if FileVault is enabled on the startup disk.
  4. How to reset the password on a Mac, Override root/wheel for /var/db/.AppleSetupDone: шаг 4, изображение 1 из 1
    • If you get a message that says "override r------- root/wheel for /var/db/.AppleSetupDone?", type in "y" and press enter/return.
    • You may get an error that says, "rm: /var/db/.AppleSetupDone: read-only file system.
    • If you don't see a message that says "override r------- root/wheel for /var/db/.AppleSetupDone?", then continue to the next step.
  5. How to reset the password on a Mac, Reboot computer: шаг 5, изображение 1 из 1
    • Type in "reboot" and press enter/return.
  6. How to reset the password on a Mac, Setup your Mac: шаг 6, изображение 1 из 2 How to reset the password on a Mac, Setup your Mac: шаг 6, изображение 2 из 2
    • Your Mac will now reboot to the Setup Assistant. you can now set up your Mac.
  7. How to reset the password on a Mac, Congratulations: шаг 7, изображение 1 из 2 How to reset the password on a Mac, Congratulations: шаг 7, изображение 2 из 2
    • You have now created a new user account with full administrator access. And all the user accounts created prior to this remain untouched
Заключение
You have now successfully created a new administrator account on your Mac.
18 участников успешно повторили данное руководство.
Elijah
Участник с: 12/16/18
1 070 Репутация
Автор 2 руководств
5 Комментариев
What are the steps to overcome the error?
“You may get an error that says, rm: /var/db/.AppleSetupDone: read-only file system.”
dhinostroza - Ответить
This error can be caused because FileVault is enabled or that there was some random error. Try running the same commands in Terminal in the macOS recovery partition and see if that works. This error may also occur on a Mac with a T2 chip. If FileVault is enabled, you will have to erase the hard drive/SSD and reinstall macOS if you forgot your password.
Elijah -
i get no such file or directory why ???
Mohamed Barnoussi - Ответить
El nuevo usuario administrador que se crea ¿de dónde toma el nombre “Admin” que es el nombre del nuevo usuario administrador?
Horacio Gáñez
Harok Hga - Ответить
: /var/db/.AppleSetupDone: read-only file system.",
you have to allow write access to the filesystem,
but only after checking for errors.
On my old MacBookPro, it's written in the system messages:
/sbin/fsck -fy
/sbin/mount -uw /
Afterwards, it worked as described
Walter Bastanier - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 33
За последние 7 дней: 228
За последние 30 дней: 1,041
За всё время: 32,186
