How to separate or replace the links in a bike chain
Выберете то, что вам нужно
  1. How to separate or replace the links in a bike chain, Chain Breaking: шаг 1, изображение 1 из 2 How to separate or replace the links in a bike chain, Chain Breaking: шаг 1, изображение 2 из 2
    • Slide the chain cutting tool onto the desired link.
    • Align the push pin of the tool with the pin on the chain, and tighten the tool until the pin protrudes out the other side without falling all the way out.
  2. How to separate or replace the links in a bike chain: шаг 2, изображение 1 из 1
    • Stop pushing the pin out when it is just held in by the outer link, so it doesn't fall all the way out. You will still be able to separate the links.
    • If necessary, repeat the previous step to take off sections of links.
  3. How to separate or replace the links in a bike chain, Chain Reassembly: шаг 3, изображение 1 из 2 How to separate or replace the links in a bike chain, Chain Reassembly: шаг 3, изображение 2 из 2
    • Rout the chain around the front chain rings and rear derailleur.
    • Pull the ends of the chain together.
  4. How to separate or replace the links in a bike chain: шаг 4, изображение 1 из 2 How to separate or replace the links in a bike chain: шаг 4, изображение 2 из 2
    • Use the chain cutter tool to press the chain pin back through the chain link. If it is difficult to push it back in, the links are not aligned properly. Realign and try again if this is the case.
    • Reusing pins in chains can cause the chain to fail. This is because the pins are press fit into link. Using a new pin when assembling a chain is recommend for long term use.
Заключение
After re-inserting the chain pin, make sure that the chain links move freely. Occasionally, pressing the pin into the chain will cause excess friction on the side links, causing the two links to not flex properly. You can fix this by adjusting how you push the pin through, and also by adjusting the links with a pair of needle-nosed pliers.
Еще один человек закончил это руководство.
Brett Hartt
Участник с: 04/12/10
127 897 Репутация
Автор 143 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
Один комментарий
Don't possess a chain link splitter
Bobby Toner - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 13
За последние 30 дней: 59
За всё время: 5,350
