How to use a Krone LSA-Plus Punchdown Tool
Выберете то, что вам нужно
  1. How to use a Krone LSA-Plus Punchdown Tool, LSA vs. LSA Plus: шаг 1, изображение 1 из 2 How to use a Krone LSA-Plus Punchdown Tool, LSA vs. LSA Plus: шаг 1, изображение 2 из 2
    • There is a difference between LSA and LSA Plus:
    • LSA: The insulation displacement terminals are perpendicular to the cable.
    • LSA Plus: With this technology, the insulation displacement connectors are at an angle of 45° to the cable.
  2. How to use a Krone LSA-Plus Punchdown Tool, Switch the scissors on/off: шаг 2, изображение 1 из 1
    • The Krone tool has integrated scissors that automatically cut the excess when you punch down the wire.
    • To enable or disable the scissors, turn the wheel in the middle of the tool.
  3. How to use a Krone LSA-Plus Punchdown Tool, Switch the sensor on/off: шаг 3, изображение 1 из 2 How to use a Krone LSA-Plus Punchdown Tool, Switch the sensor on/off: шаг 3, изображение 2 из 2
    • The sensor is a mechanism that only allows the scissors to work if the tool is properly inserted into the LSA slot. You might want to disable it if you want to connect two wires on one contact (requires special contact).
    • To disable the sensor, move the metal bracket at the front of the tool towards the toolhead.
  4. How to use a Krone LSA-Plus Punchdown Tool, Place your cable: шаг 4, изображение 1 из 1
    • Place the cable you want to punch down into the terminal.
  5. How to use a Krone LSA-Plus Punchdown Tool, Punch down: шаг 5, изображение 1 из 2 How to use a Krone LSA-Plus Punchdown Tool, Punch down: шаг 5, изображение 2 из 2
    • Press down on the connector.
    • LSA-Plus is directionally keyed. If your tool doesn't enter into the gap, it might be because you're holding it the wrong way around.
  6. How to use a Krone LSA-Plus Punchdown Tool, Cut the excess: шаг 6, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Flush Cutter
    $29.99
    • If your scissors are off, or you're working in a tight space where the excess left by the tool might be too much you'll have to manually trim the excess.
    • Use electronics sidecutters to trim the excess.
  7. How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: шаг 7, изображение 1 из 3 How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: шаг 7, изображение 2 из 3 How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: шаг 7, изображение 3 из 3
    • Press on the tab to release the wire removal hook.
    • Use the hook to pull out the wire you want to remove.
Заключение
Good luck on your next project!
2 человек успешно провели ремонт по этому руководству.
Sebastian
Участник с: 08/19/18
31 157 Репутация
Автор 71 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 15
За последние 7 дней: 93
За последние 30 дней: 467
За всё время: 9,882
