Выберете то, что вам нужно
Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
Lift the battery from the middle and then pivot it outward to remove it from the computer.
Remove the single 7 mm screw from the top middle of the laptop using a Phillips #0 screwdriver.
Remove the twelve screws from the bottom of the laptop with the Philips #0 Screwdriver.
Flip the device around and open it. Use the blue spudger tool to remove the casing around the keyboard space by driving it the crease and propping it up.
Once you have used the spudger tool all the way around the casing, lift the casing up from the device.
Use a Phillips #0 screwdriver to remove the screw that holds the USB drive in the bottom right corner near the hard drive. Once removed, lift the USB drive off of the hard drive.
2 участников успешно повторили данное руководство.
