Введение
If you need to replace or upgrade the RAM in your HP 15-f305dx laptop, use this guide.
RAM is temporary computer storage that stores and reads data almost instantly. When opening a program, it becomes temporarily stored in your computer’s RAM. Opening multiple browser tabs or too many applications at once may slow your computer significantly. Adding more RAM to a computer allows for larger quantities of applications to run at the same time without a loss in performance.
Before using this guide, ensure your laptop’s battery has been removed so there is no chance of electric shock.
Выберете то, что вам нужно
Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
Lift the battery from the middle and then pivot it outward to remove it from the computer.
With the hinge of the laptop screen facing away, remove the panel from the laptop on the near side of you.
Press the two locking arms on either side of the RAM card away from each other.
Remove the RAM card by sliding it out from its port at the same angle at which it rests.
