Запчасти
Никакие детали не требуются.
  1. Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  2. Turn the computer upside down on a flat surface.
    • Turn the computer upside down on a flat surface.
    • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
    • Lift the battery from the middle and then pivot it outward to remove it from the comp.
    • Remove the bezel by prying it away from the screen using the spudger.
    • Remove the four 3mm PH1 Phillips head screws in each corner of the screen and do not care about outer screws.
    • Remove the screen and place the screen very softly on the keyboard.
    • Remove the sticker gently and disconnect the metal blade.
Заключение
Brandon
Участник с: 23.03.2018
607 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team S2-G3, Bernier Spring 2018 Member of UMass Dartmouth, Team S2-G3, Bernier Spring 2018
UMASSD-BERNIER-S18S2G3
3 членов
Автор 4 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 5
За 30 дней: 10
За всё время: 101
