Введение
In this guide you will learn how to remove the keyboard from the HP Pavilion dv6-2155dx.
Выберете то, что вам нужно
Loosen the screws using Phillips #01 screwdriver with the extension attached.
After removing the two screws securing the Hard Drive to the bottom case, remove the panel to reveal the hard drive.
Locate the tab of the black Mylar film on the right hand side of the hard drive.
Gently grip it with your thumb and index finger.
Pull the Hard Drive to the right to loosen the it from the frame.
The left side of the hard drive will pop up and should slide out freely until you see the black connector on it's right side, connecting it to the computer.
Turn the Hard Drive over and grasp the Hard Drive with one hand as you grip the connector with the other hand to remove the connector from the hard drive.
Remove the six screws. Four are marked with a keyboard icons, two are located on the top corner.
Remove the three screws located in the battery port.
Once the top panel is propped open, remove the three 4mm silver screws located at the top of the keyboard with a Philips head screw driver, size #1.
Flip keyboard forward and raise the keyboard off the frame.
Once you have removed the three screws, gently lift the keyboard away from the laptop.
Use plastic spudger to flip up the black strip on the ZIF connector that connects the ribbon cable to the motherboard.
6 участников успешно повторили данное руководство.
