Huawei Ascend G630 Front Panel Assembly Replacement
Выберете то, что вам нужно
  1. Huawei Ascend G630 Front Panel Assembly Replacement, Front Panel Assembly: шаг 1, изображение 1 из 1
    • Prepare your tools onto the table and make sure you have everything you need for the repair and a clean workspace.
    • Start off by opening back of the Ascend g630 by just sliding either a spudger or a fingernail in between the frame and the back cover and prying it open.
  2. Huawei Ascend G630 Front Panel Assembly Replacement: шаг 2, изображение 1 из 2 Huawei Ascend G630 Front Panel Assembly Replacement: шаг 2, изображение 2 из 2
    • Using your Phillips screwdriver, unscrew all screws on the back of the phone.
    • There is a varranty sticker on the corner screw pointed out in the picture.
    • Gently pry between the screen frame and the rear panel of the phone to expose the insides of the phone.
  3. Huawei Ascend G630 Front Panel Assembly Replacement, Remove the battery: шаг 3, изображение 1 из 3 Huawei Ascend G630 Front Panel Assembly Replacement, Remove the battery: шаг 3, изображение 2 из 3 Huawei Ascend G630 Front Panel Assembly Replacement, Remove the battery: шаг 3, изображение 3 из 3
    • The first picture shows a handy way of finding the correct placement for the battery screws when reassembling the device.
    • Disconnect the battery and unscrew the 2 screws holding down the battery. Remove the battery.
  4. Huawei Ascend G630 Front Panel Assembly Replacement: шаг 4, изображение 1 из 3 Huawei Ascend G630 Front Panel Assembly Replacement: шаг 4, изображение 2 из 3 Huawei Ascend G630 Front Panel Assembly Replacement: шаг 4, изображение 3 из 3
    • Disconnect the flex cables from the motherboard.
    • Carefully pry the camera loose, so that it can be removed along with the motherboard.
  5. Huawei Ascend G630 Front Panel Assembly Replacement: шаг 5, изображение 1 из 3 Huawei Ascend G630 Front Panel Assembly Replacement: шаг 5, изображение 2 из 3 Huawei Ascend G630 Front Panel Assembly Replacement: шаг 5, изображение 3 из 3
    • After undoing the flexcables the motherboard can be released (3 spots marked red) and removed.
  6. Huawei Ascend G630 Front Panel Assembly Replacement: шаг 6, изображение 1 из 2 Huawei Ascend G630 Front Panel Assembly Replacement: шаг 6, изображение 2 из 2
    • Remove the volume buttons & flex cables and everything else that might be missing from your new replacement part.
    • Carefully pry under the flex cables with a spudger. The flex cables are held down with mild adhesive. A bit of heat might help, but using a heat gun for this step is optional.
  7. Huawei Ascend G630 Front Panel Assembly Replacement: шаг 7, изображение 1 из 2 Huawei Ascend G630 Front Panel Assembly Replacement: шаг 7, изображение 2 из 2
    • Remove any protective films (blue in picture).
    • Make sure the flex cable pointed out in the second picture is glued to the back of the display. A bit of thin double-sided tape will do, if there is no adhesive left on the flex cable.
    • As you reassemble the device, make sure you wipe the contacts you have touched with your fingers, with isopropyl alcohol or similar.
  8. Huawei Ascend G630 Front Panel Assembly Replacement: шаг 8, изображение 1 из 1
    • Finished!
Заключение
To reassemble your device, follow steps 2-6 in reverse order.
9 участников успешно повторили данное руководство.
Antti Immonen
Участник с: 01/06/15
2 795 Репутация
Автор 6 руководств
2 Комментариев
I plan on using this dissasembly guide for replacing the usb charging port which in these pictures appears to be through-hole soldered. As a novice when it comes to both soldering and taking apart phones (laptops are my safe zone), could you perhaps give some advice on wether this is also a known issue and if I'm risking overheating the board or other possible problems when attempting this. It's still got a lot of personal pictures and contact information on it and I'm really worried about damaging any critical memory or other operating component.
Bento - Ответить
can you add more steps if only i want to replace the GLASS (with digitizer) since the LCD display is still working good... only that the glass is severely cracked. please add photos. thanks
Ray Floyd Cabrera - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 6,639
