Введение
Replace your phone's cracked screen or unresponsive LCD display to give it a fresh appearance. The screen and LCD display are glued on and wired in place, so replacing this part requires patience. Because the screen and LCD display are one piece, replacing one means you are placing both.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Выберете то, что вам нужно
Pull and twist the pin near the bottom left-side of the phone to remove it from the headphone jack.
Insert the pin into the SIM card opening located on the right-side of the phone.
Gently push in until the SIM card clicks, and then pull the pin and SIM card out.
Repeat this process for the additional SIM card.
Firmly push down on the black plastic covering at the bottom of the phone, and pull down.
Rotate the phone 180 degrees so that the bottom of the phone is now facing up.
Firmly push up on the back panel with your thumbs.
Lift up the back panel from the top right corner and gently pull it away from the phone.
Remove the following screws securing the logic board to the main frame:
Five 2mm Phillips #000 screws
Two 2.5mm Phillips #000 screws
To replace the battery only the two orange 2.5mm screws need to be removed in this step.
Push down the yellow plastic lining at the top of the battery and remove the two 2.5mm Phillips #000 screws.
Use the flat end of a spudger to gently snap open the first clip located on the the right arm of the retaining plate.
Use the flat end of a spudger to gently snap the second clip located on the left arm of the retaining plate.
Use the flat end of a spudger to gently lift the upper retaining plate from the phone.
Use the pointy end of a spudger to gently pry the following connectors out of their sockets:
silver LCD cable connector
silver Headphone jack cable connector
Use the pointy end of a spudger to gently pry the following connectors out of their sockets.
Sliver Micro-USB cable connector
Copper battery cable connector
Remove the two 2mm Phillips #000 screws securing the copper flex cable to the silver metal tab.
Wedge the flat end of a spudger underneath the bottom left of the metal tab.
Run the spudger along the bottom edge of the metal tab and gently pry upward.
Use the pointy end of a spudger to wedge underneath the black circular vibrator motor near the bottom right of the phone.
Slowly lift up to separate the black circular vibrator motor from the adhesive.
Hold down the bottom left corner of the motherboard and slowly lift the right side out of the main frame.
Gently wiggle the logic board to release it from the phone.
Use the pointy end of a spudger to wedge underneath the earpiece speaker, and gently pry upward.
Use tweezers to remove the earpiece speaker from the frame.
Use the pointy end of a spudger to peel back and fold down the black plastic cover near the bottom left of the phone.
Use a heat gun to loosen the adhesive between the display and frame.
Start with the heat gun far away from your hand. Then, slowly move your hand towards the heat gun until the air is warm, but not hot.
At this set distance, slowly warm the entire front of the phone.
Use the iSeasmo tool to wedge between the screen and the plastic near the bottom right corner of the phone. You must wedge the iSeasmo underneath the white plastic part of the screen, and not just the glass.
Run your iSeasmo tool slowly to the left and right to begin separating the display.
Run your iSeasmo tool along the right and left edges of the display.
Once the display is loose enough, gently begin separating it from the bottom of the phone. Work your way up until it is completely removed.
18 участников успешно повторили данное руководство.
5 Комментариев
Where did you buy the replacement screen?
To find the screen you are looking for just do a Google search, and you should no problem getting what you need.
After changing the ear piece, my phone refuse to display after putting it on, what could be wrong.
