Выберете то, что вам нужно
Place the phone screen down on a flat surface. Underneath the camera there will be a indentation, place your thumb or pointer finger on the indentation and pull gently up towards you. The back of the phone should pop off easily.
Underneath the back of the phone you will find the battery. The battery is located in the middle of the phone's inner backing. By the battery you will find a similar indentation; place your thumb in the indentation and lift the battery towards you. The battery will come right out.
Along the edges of the phone you will find 8 screws, to remove these screws use a screwdriver( T5 if you are using the screwdriver found in the ifixit 54 bit driver kit)
Take the screws out by twisting left and set them in a spot where you will not lose them.
Use the blue plastic opening tool by sliding it along the edges of the phone to pull back the frame.
After removing the phone's frame, you will see the camera placed in a metallic cube, to remove the cube lift the edge gently and pull to the left.
CONGRATULATIONS!!! you have successfully completed this guide, please share this guide with your friends
Yay! Party time don't forget the bean dip
