Введение
Use this guide to replace a worn-out or dead battery in your Honor 10.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Although it’s possible to remove the battery without removing the loudspeaker unit and the interconnect flex cable, we recommend doing so to make the removal procedure easier and to prevent damage to the interconnect flex cable.
You’ll need replacement adhesive to reattach components when reassembling the device.
Выберете то, что вам нужно
Before you begin, switch off your phone.
Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Press a suction cup onto the back cover.
Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
Insert the tip of an opening pick in the gap you created and slide it to the bottom right corner.
Insert a second opening pick at the bottom right corner of the rear glass.
Slide the opening pick along the bottom edge of the rear glass to cut the adhesive and leave it in the bottom left corner.
Insert a third opening pick at the bottom left corner of the rear glass.
Slide the opening pick along the left edge of the rear glass to cut the adhesive.
Leave the opening pick at the top left corner of the rear glass.
Insert a fourth opening pick at the top left corner of the rear glass.
Slide the opening along the top edge of the rear glass and cut the remaining adhesive with it.
Use a pair of tweezer to carefully peel the black foil off the loudspeaker and daughterboard cover.
Remove the foil completely.
Remove the three Phillips #00 screws (2.9 mm length) that secure the metal bracket on top of the battery, interconnect, and display flex cable.
Use a pair of tweezers to remove the metal shield that covers the connectors of the interconnect cable, the battery and the display flex cable.
Remove the seven Phillips screws securing the loudspeaker unit:
Three silver 2.9 mm long screws
Four black 3.4 mm long screws
Slide the flat end of a spudger under the right side of the loudspeaker unit.
Pry up the loudspeaker unit until you can get a good grip.
Remove the loudspeaker unit.
Use a spudger to pry off and disconnect the bottom end of the interconnect flex cable.
Use a spudger tor pry up and disconnect the top end of the interconnect flex cable.
Remove the interconnect flex cable.
Use a spudger to pry off and disconnect the display flex cable.
Fold the display flex cable backwards and out of the way to make the battery removal process easier.
Apply a heated iOpener to the screen for two minutes to loosen the adhesive beneath the battery.
Insert the flat end of a spudger at the top left corner of the battery where the display flex cable connector is located and start to pry it up.
Work your way down the left side of the battery and loosen the adhesive with the spudger.
Insert the flat end of a spudger at the top right corner of the battery to pry it up.
Work your way down the right side of the battery and loosen the adhesive.
Cut the remaining adhesive beneath the center of the battery using the spudger.
Pry up the battery until you can get a good grip.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
5 участников успешно повторили данное руководство.
