Введение
If you are experiencing issues with your phone's speaker, this guide will show you how to repair or replace it.
Выберете то, что вам нужно
Depress the top of the battery cover, and pull downwards towards the base of the phone.
Remove the battery by levering the battery out, using the cut just below the camera.
Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
Work the opening tool around the border of the camera and speaker cover, until it comes loose.
Using the opening tool, pry the back panel from the front panel.
Work your way around the phone until the panels separate evenly.
