Huawei Mate 9 Back Cover Replacement
Выберете то, что вам нужно
  1. Huawei Mate 9 Back Cover Replacement, Back Cover: шаг 1, изображение 1 из 2 Huawei Mate 9 Back Cover Replacement, Back Cover: шаг 1, изображение 2 из 2
    • First switch off your phone and remove the SIM card tray.
  2. Huawei Mate 9 Back Cover Replacement: шаг 2, изображение 1 из 2 Huawei Mate 9 Back Cover Replacement: шаг 2, изображение 2 из 2
    • Remove both screws on the bottom with a Torx T2 screwdriver.
    • Use a plastic opening tool to get between the display and the case. Open the smartphone by carefully prying out the display with all the parts out of the case.
    • Don't open the phone all the way, yet. The fingerprint sensor cable is still connected to the back cover.
  3. Huawei Mate 9 Back Cover Replacement: шаг 3, изображение 1 из 2 Huawei Mate 9 Back Cover Replacement: шаг 3, изображение 2 из 2
    • Swing open the phone to the right side.
    • Disconnect the fingerprint sensor cable with a spudger.
Заключение
7 участников успешно повторили данное руководство.
Tobias Isakeit
Участник с: 03/31/14
116 767 Репутация
Автор 188 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 506 руководств
Один комментарий
So apparently they must have welded my phone together with some unknown super exotic alloy from another planet. After spending nearly an hour removing the 2 screws at the bottom of the phone using a borrowed IFIXIT tool kit from a friend I proceeded to destroy a guitar pick, 1 heavy duty guitar pick looking thingy, and 2 separating tools from the kit and all I’ve succeeded in doing so far was breaking the bottom of the back cover of my phone. All I wanted to do was save the 50 bucks the guy quoted me to fix the charging port but now I’m thinking that’s a pretty good deal after you add up the cost of repair parts for demolishing my phone. $28.00 for a new back cover that will take 6 weeks to get , a new digitizer has to be over a hundred bucks, and how do you put a price on the frustration this is going to be if I keep going? Do yourself a favor and have someone else work on your device while it can still be saved. These 2 suction cups seem to be stronger than me and I’m jacked!!!
Randy Simpson - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 23
За всё время: 5,046
